The lights work but noting when I turn on the key no clock radio nada.I already checked the in. switch
^^ in addition, its says "alt" on the top of the box its your alternator fuse, if you have a fusable link, and its burned up it can be replaced with a one of the big fuses instead.CRE said:It's in the fuse box by the battery. Try searching "fusible link" if you need more info, it's been discussed at length here quite recently. There were two types used, one looks like a thick wire, the other looks like a huge fuse.
my fusable link burned up, and I switched to the fuse their a lot easier to find, everyone at the auto store around me didnt even know what a fusable link was:nuts:CRE said:If it's the wire type of fusible link it's bolted in from the bottom. The socketed type don't just drop in... but if that is the problem it wouldn't hurt to switch.
