Hey guys so the rebuild is done. its a 7MGE with W58. im getting no power at all. on my first drive out it got hot so i turned it off and got it home. took out the thermostat and it doesnt get hot. So now running it with no thermostat and its not going past the 1/4 mark. now i checked the timing and all the marks are aligned. Crank at 0 and timing marks aligned with back plate. I adjusted the distrubutor and its idling normal. however when i rev to 3000 and lift off, RPM drops to 500 and the car struggles to stay alive. It recovers and idles normally around 900 after that. Now my main problem is when i took the car for a drive i had ZERO power. The thing will not pull. i didnt adjust TPS according to TSRM. I hear an AIR leak around the intake manifold near the firewall. All the Vaccuum hoses are connected and connected correctly. Someone please help. Where can i go from here. It does smoke when cold but then no smoke once its warmed up. Im scared i installed it wrong and have BHG AGAIN. i know im all over the place but im just exhausted and need my baby to run. Ohh and im getting good compression all round around the 150-155 mark. Please Help
I reused the old injectors and old spark plug wires. I had to splice new injector connectors into the harness as the old ones were hardened and snapped while pulling them off.
