Help: Need part #s to finish my 2jzgte vvti swap in my 89 MK3
AE86BLISS
Oldschool FTW!
Mar 19, 2011
128
MI
I've been looking and still have had no luck.
I need the part #'s for..
2jzgte rear sump set up - Oil return flang and the 2 oil return rubber lines.
2jzgte - alternator harness plug.
steve_mk3
middletown, NJ
Upper and Lower Oil pans w/ required bolts – From Elmhurst Toyota
12111-46052 Pan Upper List 358.79 Cost 273.94 X 1
12102-46031 Pan Lower 127.81 Cost 97.59 X 1
90430-12031 Drain Plug Gasket List .98 Cost .73 X 1
90341-12012 Drain Plug List 3.66 Cost 2.71 X 1
96721-24031 O Ring List 2.54 Cost 1.88 X 1
91512-b1055 Bolt List 1.18 Cost .87 X 6
91511-j0820 Bolt List .71 Cost .53 X 16
90116-06127 Stud List .71 Cost .53 X 4
90119-06624 Bolt List .80 Cost .59 X 23
90182-06257 Nut List .49 Cost .36 X 2
00295-00103 Fipg Pan Sealer List 12.78 Cost 9.36 X 2
-Oil pan baffle – 12121-46030 List 13.83 Cost 10.57 from Elmhurst Toyota
-Oil Pickup tube w/ gasket & bolts - from Elmhurst Toyota
15104-46030 List 48.93 Cost 37.36
90182-06005 Nut List .55 Cost .41 X 2
91621-60612 Bolt List .60 Cost .44 X 1
15147-ad010 Gasket List 2.40 Cost 1.77 X 1
AE86BLISS
Oldschool FTW!
Mar 19, 2011
128
MI
I have the rear sump setup. I just need the oil return lines and the flang they connect too for the turbos.
It's not all the same as the non Vvti 2jz?
If it is champion or elmhurst Toyota on sf can get that. I don't see why it wouldn't be the same.
AE86BLISS
Oldschool FTW!
Mar 19, 2011
128
MI
I'm not saying it may or may not be the same. I'm just looking for the part #'s before I call Elmhurst. Last time I called and didn't have a part #, who ever it was I talked to gave me a hard time.
The reason I need the oil return flang and two oil lines is because I had a front sump and when I did the swap to a rear sump I didn't have the flang and the 2 rubber oil return lines that come from the turbos to the flang.
I also need the Alt harness plug, I never got mine back from Dr.Tweak when he did my harness.
After I get these 3 parts I should be able to turn my key and start this beast for the first time sence I got the 2jz in it. ;)
AE86BLISS
Oldschool FTW!
Mar 19, 2011
128
MI
Well seeing that no one knew the part #s, and I can't find them. I went another way. Here is what I came up with.
I still need the 2jzgte - alternator harness plug.
Please if any one knows help me out.
