All,
My engine needs rebuilt. 87 Turbo with 62-1 Garrett Turbo P-Trim, Lexus/550, SAFC I, AFPR, Walbro, 3 inch exhaust. Max HP want to achieve = 500. Car already has HKS 2.0mm metal headgasket and ARP studs, rebuilt manual transmission, remanufactured head.
I don't understand what is compatible when something is oversized, so any help in any of these is appreciated (non standard stock sizes).
I want to purchase the following new from Toyota (makes sense with a rebuild):
1- Timing Belt
2- Oil Pump
3- Water pump
The following from horsepower freaks or similar company:
4- Pistons with wrist pins, 0.40 oversized
5- Eagle Connecting Rods -- what do I need for the 0.40 oversized pistons?
6- ARP Main studs
7- Thrust washers
8- HKS Stopper Headgasket 2.0mm 86mm bore <-- is this correct?
9- Rod Bearings - I can get standard, .25, .50 or .75 mm over. How do I know what I need?
10- Main Bearings - I can get standard, .25, .50 or .75 mm over. How do I know what I need?
11- Valves
I know what these look like and what their function is but I am not sure about compatible sizes.
1- Timing Belt
2- Oil Pump
3- Water pump
6- ARP Main studs
7- Thrust washers
11- Valves
