I have repaired alot of heads, if done right with the right grade alum filler you should be fine. Just weigh your options first of repair cost vs a good used head.
NashMan;1762612 said:then number 2 just tuched and got ass pounded
NashMan;1758280 said:well i should beable to sand it out but we will see
Kai;1762726 said:I'm sorry did i just hear you say you're going to SAND a head? :nono:
NashMan;1752715 said:cleaned my head found this
pretty much knew what happen now
biggest question now is this head now junk ?
kinda bumbed right now since it will mot likly get replaced or all ground away and reweled
You could order a new head while sitting in front of your computer... short of that, no.cricketjoe;1763206 said:is there anything i can do at home?
mecevans;1778134 said:You can use it to practice porting
