Help me ! 1jz misfire confusion
enjoi.this
Formerly ChrisC
Aug 18, 2008
674
Kelowna, BC
Car is definatly running pig rich, lots of black of the tail. Id bet its a faulty sensor or ecu like previously mentioned.
Does the 1J ecu have a fail safe mode for when it craps out? I know when an ecu on a honda is bad it will go into limp mode and wont rev over 2000 or 2500rpm I belive. Could explain why it idles fine but wont rev up. Check the ecu, seems to be the most popular point brought up here so far.
5l_eater
I LIVE FOR THIS SHIT !
Jan 17, 2007
258
Maryland
by checking it i took it aprt to look at it and i heard it would smell like burnt plastic .
ok ill check the crank sensor ...any one think it might b ICV or MAF
Slow_Sc3
I beat bikes dude
Apr 2, 2005
401
Maryland
jump the t1 and e1 and pull some codes since the check engine light is on!!!!
and idunno what 1.3 or .9 is for your spark plug gap but mine are at .28
5l_eater
Jan 17, 2007
258
Maryland
yea i the ecu can go into limp mode i dont have a extra ecu to try and dont know any one with one for me to test so i guess im fucked
Ryan_V
47
Austin
I didnt read every post in detail, but make sure you check the wiring leading from the coil connectors.
You can also pull each coil connector one at a time. If one of them doesn't make an obvisou diff in the way the engine is running, you may have a bad coil or wiring to it.
I think the plug is a result of the misfire, not the cause anyways.
S.A. supra
2,405
Buda, Texas
GAP? I also gap mine at .028 Try regaping them it can't hurt. And check your coils for cracks. My car stumbled really bad not as bad as yours, but all of my coils had cracks. Some had four or more. I bought a whole set and some 6097 gaped at .028 and it runs like a champ now.
5l_eater
Jan 17, 2007
258
Maryland
yea i tryd that coil trick by pulling them off one at time and nothing happen. yea i gapped on mm not inch ill regap tho.
Slow_Sc3
I beat bikes dude
Apr 2, 2005
401
Maryland
socalmk3;1320317 said:
Piston Rings or valves are bad? that happend to my MR2 i dunno if its the same for the 1jz...
lol you know nothing!
im going to say it has crank walk just because my dsm had that back in veitnam.
ill see what i can do about ecu but pulling your coils one at a time should have done something if it was missing on anyone cylinder....
lucas
12
portland
im kinda new to this but try changing out your coolent temp sensor. i have heard of that really fucking with how the car runs.
Slow_Sc3
I beat bikes dude
Apr 2, 2005
401
Maryland
if the efi coolent temp sensor is bad the car will just crank and crank not firing over
check you injector clips should be like brown grey brown make sure you dont have two colors next to each other
5l_eater
Jan 17, 2007
258
Maryland
sorry gmal passed away been busy heres the deal she sat for 2 days n i started her she runs like a fucking champ i mean awesome rev her up to 5 grand 2 or 3 times and it didn't misfire and no black smoke it was weird ...but ......she wouldn't idle u let of the gas n she died but the missing didnt start last time till she was warmed up but i cant do that unless she ideals
rwd
60
quebec
i had trouble like that , and in my case it was crack on each coil(check the plastic around the spring of secondary circuit),i put 3m electric tape around and the touble was fixed
5l_eater
Jan 17, 2007
258
Maryland
Fixed!!!!!!!!!!!!!!!!
I was missing the ignitor noise filter!!!!!!
Thanks to everyone for there help and advice
