I dont post alot because I really try to research before I post a question. I have a rebuilt 1990 7mgte with less than a 1000 miles. Mods: lex afm/ rc550/walbro gs315/aeromotive fpr. Issue: car was running great after rebuild but i blew the headgasket within 600 miles. took bad advice and used a copper gasket. took the head back off used cometic mls. now the car is hard to start and when it does its runs terrible when i push the accelerator it dumps so much gas into the engine until a puddle of gas is under the car. its coming out of the downpipe onto the garage floor. (exhaust is unhooked its on stands). There are no codes. I have checked everything that I know of. Grounds/temp sensor/new cps and wiring/injector resistor checks out/fuel pump relay checks out/timing is right/new coils,plugs,wires. What makes is dump fuel like that? its flooding the car. I have not checke the adjustable fuel pressure regulator because its only a year old. at this point I will try anything. Anybody please chime in with experience and advice. thanks
