The ea2
1. Black - Yellow +12 v EFI unswitched
2. Black - Orange M-REL EFI main relay
3. light green OPT, water sensor in rad
4. Blue / Blue - Red A/C speed sensor
5. Black - Red +12v EFI switched
6. Black - Red To temp sensor in rad
7. Brown ACMG from ECU to clutch
8. Light Green - Red A/C speed sensor
9. Blue A/C magnetic clutch from relay
10. Yellow - Green Charge warning light alternator
11. White AM1, ALT +
12. Black - Yellow to Alternator from engine / gauge fuse
To wire your ALT from the JZa70 it is three wires, Yellow/Green, Black/Yellow, and white. Those from the ea2 have to be ran to ma70 ALT plug. Then the power wire from your alt has to be run to the power wire from the 1jz alt, I ran mine under the rad support. Make sure on the EA2 plug you don't confuse some wires, there are doubles on black/red, one is for a different thing!! SO remember to check everything hope that helps, Im off on vacation guys!
