help from fellow '91 owners, plug to??
supra1008
1,179
Philadelphia
It doesn't go to any of the temp sensors on the water neck? o2 sensor?
<<As you can see I don't have the stock 7m in my 91 anymore.
8,898
The EWD also shows the exact connector and its circuit. Clean the wires so you can view the color better.
Mine isn't plugged into anything on my 1991 7MGTE A340E car. And it has all options.
mstgeer
Thanks Nick. That's the type of answer I was looking for. I will zip tie it up out of the way. This car seems to have a few unused plugs, some on the inner fender under the air cleaner and some on the driver's side down under the intake manifold.
I studied the EWD for a few days and could not find a 2 wire connector with White/black and yellow wires to it that would be where this connector is on the harness.
I have the oem paper copy manual for the '91 model, if you ever need any info out of it.
8,898
It could be a California plug, or even Canada. It doesn't look long enough to reach the headlight relay. The only thing over there is the A/C switches. I don't know where it goes. I didn't find the plug in the EWD.
