Help Factory radio locked...
yask4it
7m nut!!!
Oct 14, 2006
23
north carolina
Well took the radio out and put it in the freezer overnight took it out let it sit in room temp.. Then put it back in and it is still locked... That myth has been busted.... The serial number is so faded that I can'y even read it...
89 Black Beauty
Supra Alarm & Stereo Guy
Jan 11, 2006
Abbotsford
My godness people, thank God you have an installer on the boards....
You have 3 options.
1. Easyest way would be to give toyota your VIN and they will give you the unlock code (assuming you have the radio that came with your car).
2. Buy the toyota wiring harness for your car from any stereo shop and take the radio out and plug in the harness, the harness is colour coated for the speakers, ground, accessory, constant. Test the wires with any battery and if you hear a "pop" then your speakers work. (White=LF / Gray=RF / Green=LR / purple=RR)
3. if all else fails then cut the plug off and test this out...
Right Front Speaker (+) Green Gray
Left Front Speaker (+) Pink White
+12 Volt Ignition Wire Gray Red
+12 Volt Battery Wire Blue w/ Yellow Stripe Yellow
Right Front Speaker (-) Blue Gray w/ Black Stripe
Left Front Speaker (-) Purple White w/ Black Stripe
Ground Wire Black Black
Power Antenna Wire 1 Blue (join wires 1 & 2
Power Antenna Wire 2 together to this blue wire)
Do Not Use
Right Rear Speaker (+) Red Purple
Left Rear Speaker (+) Black Green
Right Rear Speaker (-) White Purple w/ Black Stripe
Left Rear Speaker (-) Yellow Green w/ Black Stripe
lmk if any of this helps
2jzmk3
Guest
uask4it said:
I like your "unique" userid..lol
yea i like it too..
Warning...
Thread hijack underway...
kntmikado
Rage Your Dream...
Apr 2, 2005
116
East Troy, WI 53120
I'd be willing to bet he means the model of the radio. The model of the car is more or less a given, and irrelevant anyway since Toyota used radios in lots of cars.
Oct 11, 2005
3,819
20
Thousand Oaks, CA
PM sent.
The instructions for entering the master code are attached to this post.
