You can do either... but you will need to have provisions to run both, which is pretty easy... the bosch valve uses 1" ID hose and the ssqv is obviously a flange type. So it would be pretty easy to run both on a stock IC piping setup.
Just get the ssqv pipe that comes in the kit and use the 3K pipes nipple to run the bosch valve. Though I believe that is a 5/8" nipple? Not too sure, wouldn't be too hard to adapt if it is...
For the record I have 2 used Bosch bpv i'll sell if anybody wants one. Im installing a ssqv on my saab later this week.
Tim
Tim
