Hey guys, I recently fixed up my Supra, and dropped the transmission to do a clutch change. I got the F1 racing stage one clutch in there right now, flywheel was resurfaced, new pilot and throwout bearings as well as the clutch and pressure plate (F1 kit), After installation the idle is fine at around 7-800 rpm, but when you start revving the motor to about 1600+ RPM you get a noticeable vibration, whether it be the clutch pedal down or not, the vibration does NOT get worse as RPM increases, stays steady, could anyone help me figure out what could be the issue, as well as any possible fixes to it? Ive searched online and they said pinpoint where the unbalanced part of the Pressure plate is (?) and add washers on the bolt on that particular side to balance the rotation of the crank but its a rather time consuming and tedious process, I don't want to drop the tranny again nor do i want to damage anything to the motor, it never did this before i changed the clutch, if anyone can shine light on this, please let me know. Thanks
