help asap
JesseH
1,153
ok, so I was gone the whole weekend going to get my gte motor, so the supra sat for 3 days, I just got home yesterday (it was raining) and drove maybe 8 to 10 miles.....ran fine, came home for maybe about 2hrs tinkering with the new motor, then left again (it was raining harder) pulled up to a stoplight and the whole car died...no weird noises etc, just cut off.... wouldn't start....waited maybe 5 to 10 min and it fired right back up... listened under the hood and there was no odd noises...ran smooth as it norm. does. When i got home i turned it off i tried to fire it back up, and it started normally. Now today when i went to start it it turned over like normal but wouldn't fire then when I stoped cranking it it had a very low hesitation like it was choking....then white smoke came out of the intake...its not a coolant smell. I am really puzzled right now and have no clue what this could be. any help would be great.
-Jesse
JesseH
1,153
D34DC311 said:
White smoke in the intake????
Was it blueish white? maybe?
no, pure white.....and it smelled odd...not like coolant, or oil, or like anything burned up. Someone told me to check the plugs to see if they're really fouled b/c they said its sounds like a bad backfire. Ive pulled half the plugs now and they do have a decent ammount of carbon build up on them
TooGoode
rediculous DD
Mar 1, 2007
549
Chandler, Arizona
had the same problem.....i believe you have a ground loose...chech your grounds around your brake master cylinder area...the one thats loose should have like 6 wires in one connector....
