Heater On of Off?
TooRandom
80
Seattle, WA
Is it better to have the heat on or off when racing?
I tested it out with out the heat on and it was good. but when I had the heat at 85 on auto it seemed to pull harder. I thought you loose hp when you have the heat on. ><"
HommerSimpson
1,067
New Smyrna Beach Florida
Your cooling system should be up to par for racing... only reason to turn heater on would be to ad just a tad bit more cooling power... If you need to turn heater on to keep temp down... you need better cooling system...
For racing... take heater out...less weight...
