I have a 1986.5 N/A Supra. The heat on it doesnt work and i have been going through known problems. So i was hoping based on the information i you all here on SM could give me some help!
The heater valve, the on operated by vacuum. When i take the vacuum line off of it, the little valve on the bottom of it. Kind of looks like a arm for the valve, goes straight down and sticks downward. When i put the vacuum line back on it goes straight up all the way and stays there regardless of what i do on the Climate Control on the car. Is this valve supposed to be down or up, when talking about the arm, when i have the heat on?
Also, when i leave the vacuum line off, if this is full open to the heater core, my car still doesnt blow hot air. I was thinking i might need to flush my heater core. My passenger side floorboard doesnt have any antifreeze on the floor so Im fairly sure it isnt cracked or something along those lines.
Third thing i have is that my climate control will blow AC just fine. But nothing wil ever blow out when you put it on low blow setting. So this might be a control problem. But if this was ture, would when i took the vacuum line off wouldnt matter, and im back to flushing my heater core?
Any help is appreciated, i tried to be as thorough as possible.
--Eric
--Eric
