Headlight problem
my7mgte527
question. my 1987 mk3 is having headlight problems. the switch was replaced all the fuses are good and the relays were replaced but they wont turn on and they driverside light goes up but the passanger side wont go up either any suggestion bc im totally lost:1zhelp:
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Next thing I would check is the wiring... had a similar problem on mine, the car was lowered, and the wiring harness under the fender drooped low enough for the tire to rub. Chewed through the wire that sent the UP signal to the headlight. Sure was a PITA to find and fix.
