I have a question. I've been following this thread and I read about the pule firing pattern earlier and it seemed to make sense to me, odd cylinders go in one cycle and even in another. It just occured to me though, why does it matter that the cylinder fired at the same time lead to the same collector. As it is headers they are setup 1-3 in the first collector and 4-6 in the second, but what would be the difference if they are groupped 1/3/5 and 2/4/6 into the first and second collector, respectively.
I understand on the first cycle, 1, 3, and 5 will flow together into the first collector and through the exhaust, and the second cycle will also group the exhaust and send it through ghr second collector to be expelled. It seems that even it the headers were left as they are, two collectors would vent the gases through the exhaust, no different destination, as opposed to one at a time. One collector will have gases coming from one primary and the other will be from two primaries but both collectors join and head to the same place.
I truly don't understand, so I'd rather ask than shrug it off or hope for an answer to pop. I realise I might be missing something and due to the night I had, I'm definitely not at my sharpest, but I'm not high, hungover, or a complete moron....imo
The only application I can think of an answer for this is a turbo car, since they exhaust gases are re-circulated then maybe vent one cycle through one collector at a time would give a higher pressure feed to the turbo possibly for a better spool. I've put some thought into it when it hit me and I don't quite understand, can someone enlighten me please?
