Ive been reading around and everyone has different opinions. My car has about 10k miles on a rebuild from the previous owner, and i want to know if i should retorque the stock bolts? Or just buy arp bolts?
92TealSupra;1292281 said:If you know it was " truly " replaced then I would re-torque it.
I have had plenty of success with 74 FT-LBS.
When you do this, hopefully this will help the guy last a little longer.
BLACKCAT;1292456 said:Just get the ARP studs, not bolts.
With the engine dead cold remove & replace the original bolts ONE at a time, working in backward sequence as per TSRM tightening order.
Make sure you install the washer first, facing the right way up.
Boosted516;1299450 said:would it be bad to retorque with original bolts? cause this would be the third time. if not im just gonna follow this link. http://cygnusx1.net/supra/TechTips/head_retorque.aspx
IJ.;1292656 said:BC: How do you chase the lower 1/3 of the hole?
thevork;1300264 said:you can retorque the stockers just fine
jdub;1300676 said:What were the stock bolts torqued to?
figgie;1300336 said:Dunno about BC but I use a Bottoming tap works quite well.
Of course it is a $65 dollar Tap but when you want the job done right.
I tried thread chaser, the crap that I purchased ended up sheering inside the block...
