Jimbo;1811699 said:Set the timing at Top Dead Center and all head bolts should be easier to access.
wardog;1811719 said:Even that wont work he NEEDS a 3/8 thin wall deep well socket. Just spin the cams until you can get the socket in.
jdmfreak;1811728 said:![]()
That cam "hump" has no flat spot:/
A3/8 will have thinner than this??? All the ones I have were thicker
Sent from my C771
Jimbo;1812123 said:Just try the shortest 3/8 drive socket you can find with an extension first while you turn the cam (have you even tried that yet? I cant remember but maybe its oval shaped) and make sure its the right mm size.
You can store the head upside down on a piece of wood with the cam caps are still on.
IJ.;1812237 said:Plasma
Notice how the wheel looks sandblasted?
This was a split second on the dyno, yours looks like you were into it a bit longer!
