Head removal question
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
I have head studs and I can't get my 12 point past my cams.... is it possible with the right tool??? And if so where would I get such a skinny walled socket......or would i have to remove my cams to get the head off
Sent from my C771
toyotanos
What will we break today?
2,842
Coon Rapids, MN
You just need to rotate the cams so the socket clears them. To be safe, I roll the engine forward ~30degrees so there's no chance of hitting valves and pistons.
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
huh... are our engines interference ???.... I am headed to my car now so I can post pix of my issue...
Sent from my C771
13mm 12 pt should be a little skinnier. Iirc
It works.
But ya just née to rotate cams.
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
Its not the cam lobes that interfere :/
Sent from my C771
Mr Bojangles
268
Madison, WI
It's not hard to remove the cams. Just keep track of all the caps and their positions and then oil journals and torque them back correctly.
radiod
1,342
Abbotsford, BC
CyFi6;1811594 said:
You must not have stock cams? All the cams I have ever seen have had two flat spots on that round area you are hitting.
Yeah, the stock cams have flat spots there that you could hold with a wrench. As for cam removal, here's the TSRM link :)
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=EM&P=41
and installation....
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=EM&P=48
Definitely keep them in order and put back in the same spot that they were before (mine were stamped I1 - 17 and E1 - E7 with an arrow for direction forward from the previous owner, made it a heck of a lot easier).
toyotanos
2,842
Coon Rapids, MN
Strange, my BC272's and stockers don't have interference like that...I'd be very interested to find out exactly what those cams are!
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
So would I the guy I got the engine from says they came on his first supra.... he thought they were stock
Sent from my C771
