Hi all, I was wondering if anyone else has had the problem of the 3 plugs in the head between the spark plugs leaking coolant. Here is a link to a write-up on the problem.
http://www.cygnusx1.net/Supra/TechTips/head_coolant_leak.aspx
If you have had this problem and used an approach similar to this to fix it, my question is, did you use the Permex Ultra Grey? Even if you did use it or didnt use it, what would you recommend using as a sealant?
Thanks.
Thanks.
