having problums with my 7mge
jono
52
Prescott, Arizona, United States
when i first got it started right up with a bhg and ranned good but now i took it all apart got it all cleaned up pute new head gasket, hole new head gasket set, new oil, new oil filter, new spark plugs, new spark plug wires, and the timing i pute the came gears allined with the lines and i turned the bottom crank shaft and allined it to 0, but idk it wont start
jono
52
dumbo;1292114 said:
Did you put the number one cylinder at TDC? And everythign is plugged in and grounds are all connected?
yeah i set the number one cylinder at tdc, yup every thing is pluuged and im prity sure grounds are pluged to, but the engine does turn over but no start
AJ'S 88NA
2,419
Florida
If you lined the marks up, it should start if everything is hooked up right. Check the ground wires that are connected to the lower manifold. It's been known that those will just fall into place right to the starter and look like they belong there....wrong :)
jono
52
ok theres thise wires i have no idea where they realy go by i mount them on here on tha manifold heres a pick http://i148.photobucket.com/albums/s19/jonhanson1/DSC00658.jpg
dumbo
1,911
Albera, Too Far North
Can't put my finger on those wires sorry. Where is that vacum line going/coming from? And what is that(wire?) near the bottome left, its black and pretty big?
Like CyFi6 said, did you line up the distributor properly?
Your CEL works, check for codes.
http://cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?Section=FI&P=23
So does it try or sputter, do you have spark/fuel?
One last thing, even I can tell you, you wont get many responses from the "Old School"/educated guys/gals around here(Who have a wealth of knowledge) unless you put a good effort in and do as people are asking, and believe it or not, grammar is important.
SupraCobra
45
Melbourne, FL
CyFi6;1292740 said:
You probably didn't line up the distributor properly, it can be tricky to get it right.
Agreed.
Same thing happened to me and the timing on the distributor has to be pretty close to 10 degrees BTDC before it will start. Also, let it sit a while before starting it because the plugs are prob soaked in fuel. Unless you want to take each one out and torch the ends with a flame.
To put the distributor in time.
Put piston 1 at 0 degrees TDC, then take the Distributor cap off and make sure the arm is about 5-10 degrees after the plug wire #1 contact. Line your distributor up according to the TSRM.
http://cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=IG&P=17
http://cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=IG&P=18
http://cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=IG&P=19
Make sure you don't mix up Clockwise and counter-clockwise like i did!!! :p
jono
52
SupraCobra;1293761 said:
Agreed.
sweet man ima try that out cuss i took those spark plug out and where soacked with fuel. ill let you know what happends
