Having problems separating 7mgte motor and tranny
Nate
GSWAG
Dec 26, 2006
31
Queens
Any advise on how I can separate the engine and tranny its out of the car and I tried while it was on the hoist and I put it on some tires and I acnt get it free all the bolts are out and the starter.
HommerSimpson
1,067
New Smyrna Beach Florida
torque converter bolts out ? bottom braces ?
100% sure its all unbolted.. put a block under bell housing infront of trans pan.. let down with engine tiping fwd..... jump up and down on tail shaft ?
Nate
GSWAG
Dec 26, 2006
31
Queens
There is enough space between the motor and trans to put your hand in I was told to twist and pull
Nate
GSWAG
Dec 26, 2006
31
Queens
jmanbball;1096615 said:
If its a manual, you need to pull out the clutch fork through the access panel on the bellhousing.
The access panels are the two black plates bolted on the bell housing right? How do I pull out the clutch fork?
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
you take off those panels, there a c-clip that holds on the big ass pin in the middle of the clutch fork. you'll see it... just pop that off and then get a screw driver to lift the pin up and out comes the shift fork.... and then apart comes the transmission!
i learned the hardway like you did too...
jmanbball
Yellow Jacket
Apr 17, 2006
234
Hittin' the books at Tech
You dont have to do that, it just pull out. I will admit though, that I did it that way the first time I removed my transmission.
Nate
GSWAG
Dec 26, 2006
31
Queens
So it can be taken out by just pulling?
Not trying to sound like a dick, but this is all in the TSRM and doing a clutch on an R154 has to be done EXACTLY as stated in the TSRM or it will fail...
Read the manual so you don't mess anything up.
tomsupra48
51
south carolina
i just had my r154 out a few months ago ... you have to make sure you take ALL the clutch cover bolts out through the check plate.... if you dont have ALL of them it wont work... and there is a bolt like up top of the starter that is a total bear to reach and take out make sure its out too you might have missed it ....im having the shop pull my tranny next time its a total pain if you dont have the right equipment... some of those bolts are like next to impossible!!
