already tried that ^
it moved the bearing out just a bit, but it didn't move any more with many tries after that.??
p5150 said:I always change it if in doubt or when I dont know if/when it has been changed.
The easiest way to get out a pilot bearing is by packing the back of it with grease through the center hole. Get an object just a bit smaller than the pilot bearing center hole like a metal dowel, bolt, punch, 1/4 " drive extension, etc and put it in the hole. Tap it with a hammer.
You may have to put more grease in each time it moves a bit but it will come right out. Hydraulics man.
supraguy@aol said:I've also heard of the wet tissue trick. Same idea as the grease, it's just perhaps a bit more forceful, as the tissue is more of a solid than the grease.
pimptrizkit said:...Many words....
Poodles said:I learned after tearing a knuckle open trying to get my turbo off the first time, that the right tools make life SOO MUCH FUCKING EASIER.
I now buy the tools I need.
Snap rings on the throwout bearing assembly? Easy, go pick yourself up some retaining ring pliers from Sears and be done with it. I had to do the screwdriver trick the first time and it SUUUUUUUUUUUCKED.
Worth the money even though I'll use it maybe once...
Poodles said:get em from marlincrawler...
they're more durable, and overall better...
get both the seat and socket...
http://www.marlincrawler.com/htm/transmission/5a.htm
