BryanDyer;1976402 said:Because the system was designed on having it recirculated. The afm meters the air before the turbo. Once the bov releases the air it goes back into the intake before the turbo after the afm. If the air is not put back in, it causes a rich condition Becuase the computer monitored the air and added fuel to make up for it so if it doesn't receive the air it "thinks" it's going to it runs rich and causes it to stall Becuase the air was not there to burn the fuel.
I'm well aware of how a closed system works. What I'm saying is I don't think that by changing one thing such as releasing metered air is going to cause the entire system to stall.
Take a running engine, now spray carb cleaner into that engine. What happens? The engine chugs for a little bit but clears back up. I know if you continue to spray carb cleaner into the engine, it will eventually stall. There's no way just the BOV can cause it to stall, especially from higher RPMs as the ECU cuts power to the injectors on decel.
