Has anyone tried those projector headlights?
Suprastic
727
Manitoba
I thought that I read in SF that they were crap. I was going to get them because they were a cheaper alternative to the Bosch kit. However I want to do a HID conversion and I heard taht you can't use ebay housings for a HID kit.
supradan22
NA->TER
May 20, 2005
915
ORLANDO FL
Im pretty sure you can use them for an HID conversion but I would have to look more into it, never herd of any H4 housing not able to do an HID to me it was a big improvement compared to the stock ones.
Fastway135
149
Mass
supraman7mgte said:
I have a set on my car,and with a set of blue bulbs look and work awesome
Looks good. If they're brighter than stock I might just give them a try too. Do you have a pic with the lights on?
lifesnotfair
356
Dominican Republic
That's what I needed to know, I'll order them really soon. If they light up some more than stock ones, then I might not need HID's.. although as someone said here, (supradan?), it's unsure wether you can use HID's or not.
Thanks for the pics bro! Although I must admit I don't like the work on your bumper at all!!! =( ... But, to each his own, if you like it, good for you! :)
N
NDBoost
Guest
i spent $110 shipped from www.rallylights.com for a set of Xenon 100% white H4 bulbs and housings. Keep in mind these are TRUE H4 bulbs & Euro Hella housings, not the fake plastic/tin foil housings on ebay. Alot of times the ebay housings their reflector material isnt setup right and projects light the wrong way.
Awesome buy but they need major adjustments to line them up properly (since their euro). I was going to get the Ebay bulbs and housings just to try them out but i just went with this set. Hell id buy the Ebay ones just for the hell of it.
lifesnotfair
356
Dominican Republic
Hey Sabotage,
I just ordered them. 10.99 + 20 shippping... 30.99... if it doesn't work out well, at least it's not a hell of a lot of cash, and maybe I could resell =P
But I'm hearing good comments on them. It comes with a pair of H4 bulbs, and the ad says it's 60% brighter than stock. I know ads lie all the time, but hell, if it's 1/3rd of that (20%) brighter than stock, I'll already be happy. Plus, with this projectors, when a bulb dies, I only have to buy the bulb, and not like now, where I have to buy the whole thing... (sealed beam, is it called? I dunno, I haven't had to buy one yet for my car).
Another thing: isn't the alignment easily done to our pop-ups? There are two things to adjust the headlights in there.. I've never touched them, but I know they're there =P
N
NDBoost
Guest
yup 2 screws one on bottom and one on the side, just park the car 25 feet away from a wall measure distance from halfway between light housing and floor and then adjust accordingly.. ill see if i can find the full directions
EDIT:
checkout www.rallylights.com for just about all the info youd want/need on H4 and HID lighting :)
Red Dragon
Keep That on the Down Low
Jan 5, 2006
318
Austin, TX
since we are loosely discussing headlamps, has anyone here ever mounted two small side by side round lamps in our housings? I saw a pic of this done on an mkiii once and i thought it looked great. Anyone done it/ have any info on it?
thanks
N
NDBoost
Guest
SupraNicholai has done it on SF. you can buy the projector lights @ www.rallylights.com they are 90mm round lights, it will run you about $200-$400 not including mounting hardware (which as to be custom fab'd)
