WillieLZG;1501522 said:So 4pt harness no good because you will slide out but what is stopping us from sliding out all car seatbelts since since nothing is retaining us underneath anyways.
My opinion is that proper 4pt harness will retain you better then stock seatbelt will. As for the titan motorsports bar i was thinking of buying it but now it sounds like it's more like a titan death bar if you get in a accident. So i'll look into the bars design more thoroughly and see whats best for my safety.
a three point harness as standard in cars allows your right shoulder to go forward which prevents your from being sent under the belts. 4 points worn properly can minimize the risk of submarining however there is still the possibility. 4 points do reduce chest loads in impacts but I would prefer to spend the extra twenty bucks to have the 5th harness
anyone looking at installing a bar or a cage should not use stock seats with anything other than stock belts. also if you are installing a harness please read this below
http://www.schrothracing.com/sdocs/2009_Competition_Instructions.pdf
safety is a really big pet peeve of mine. I know some but not enough about the subject and try whenever i can to read up on the newest technology and information.
