Guaging intrest/worth of a 7m
mkIIIdriver30
20
Coopersville Michigan
Well I am thinking of getting out the supra world. I have been working on my 91T for some time and have lost interest. I would like to know the worth and interest of my motor that I have.
I have been building my motor and have dumped a lot of money into it and know that I will probably never get it back. I just want to know what you guys think it would be worth.
The motor is a completely rebuilt 7M. It has Ross racing pistons and the block has been bored for the correct clearances. The rods have been reconditioned and properly balance and a very respectable machine shop. The crank was check for trueness and polished.
Pretty much everything in the motor is new. It has all new bearing every where including mains, rod and oil pump. It has all new shims in the head so that valve lash is right in the middle. The valves and seats have all been cut to ensure propers seating, along with all new seals. The has been cleaned to look like new, and is mildly ported.
Oil pan was dipped to remove all oil residue. Everything in the bottom end was blue printed (plasti gauged for hours) to ensure perfect clearances. Also it has ARP rod bolts that where torqued and checked with a stretch gauge to make sure of proper poundage.
HKS MHG with arp headstuds have been installed. The head has been decked along with the block surface to proper specifications to ensure no defects in the mating surfaces The exhaust, intake manifolds, along with the turbo elbow are also ported.
Every gasket and seal was replaced with the Toyota gasket set for this motor. It also has a brand new(not reconditioned) oil pump,oil pump drive shaft, knock sensors, oil pressure sending unit, and temperature sending unit.
The turbo has been upgraded by performance techniques so that it is now a 60-1. It has a brand new Toyota timing belt along with many other parts I sure I have forgotten.
I do have all receipts for this build. The motor was built at a reputable racing engine shop (which I am employed) I put most everything together myself and enlisted the help of my boss on areas I was unsure to eliminate any putting together of things wrong.
Sorry for such a long post
Jake
<edit IJ>
why are you getting out of the game?
dumping money into it and not getting a chance to enjoy it isn't a good return on investment.
I've wanted to throw in the towel and quit so many times, but once it's back up and running, I laugh at myself for being so silly...
ms07s
TORGUE!
Sep 29, 2007
1,083
Memphis,Tn
Good! Dumping that much time and money into it only to give up is sad. If I had a dollar for everytime I thought about giving up on my car I could afford a 2009 GTR.:naughty: Just stick with it and you won't regret it...V8's suck anyway:sarcasm:
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,777
Long Island, Ny
v8's are over rated, high fuel consumption, one set power level, starting to sound worse and worse.
Keep the supra and base your power level on injector and turbo size rather then rebuilding every time you feel you need another 50 horsepower.
Turbo V8 is too much money anyway.
The1
Too poor to be here..:(
May 24, 2007
228
Austin, TX
I thought about giving up last week....lord knows I did. But now I'm working on it and want to give it up more..lol. It just made me want to buy all new parts...
