The guage reads normal (about 3 notches below horizontal), but the engine is really warm. Everything in the engine bay becomes to hot to touch, not just warm.
I just finished a rebuild on the motor and I set the timing, and then discovered a code 51 (TPS). I fixed that and went to reset the timing and found it about 5* retarded. I have not tested the thermostat yet, and It still has the jiggle valve.
What is the difference of Yazaki and Nippondenso?
What resistance am I suppost to be seeing at operating temp? 40 or 50 ohms?
