Group A's group a rebuild
bryank
14
Bournemouth, UK
IJ. said:
Thanks Bryan!
Would love to get my hands on one so I could see just how it works ;)
lol will see if anyone has a diff kicking about with the cooler :)
As far as i know it's just like a little heat exchanger, with one end in the oil and the other out in atmosphere.. sure someone called it a cooling tower at one point.. Assuming the diff cases are the same worldwide and have a blanking plate where the cooler would be, i'd guess it'd be just a bolt in item?
Cheers,
Bryan
Bryan: Nope our cases don't have a plate at all so I guess it's Case specific!
I had guessed it was some sort of heat pipe arrangement :)
(wonder if it makes a difference I've cooked the pinion bearings in 2 diffs running at high speeds now)
group a supra
SPAWNING AN INTERCEPTOR
lmao ian
today
ordered oil system parts as i need to ensure they fit before i weld up the manifold and realise there is no room for a filter remote cause at that i would be pissed
so today i have ordered a burns muffler 4"
http://www.burnsstainless.com/UltraliteMuffler/ultralitemuffler.html
and some canton parts oil rmote adaptor for the block and billet black filter mount + thermostat unit
http://www.cantonracing.com/oil_cooler_thermostats/oil_cooler_thermostats.html
http://www.cantonracingproducts.com/adapters/remote_filter.html
more to be ordered tommorrow andd got my welder back from the welder hospital today cost $230
total cost today so far $1500 approx doh
group a supra
ok today fitted the second solidengine mounting at last compete with 16mm bolt if these brake well i have real problems
also in the last couple of days ordered a length bein 5 metres of 5" alloy tube for the airfilter
10 90 degree elbows for the manifold
and some 4" v bands for the exhaust all be here by tuesday
IHI-RHC7
"The Boss"
Oregon
Hmm, your oil thermo is set to 215...
Isn't that a bit warm, I've always figgured 180 was the "magic" temp for fluids...
group a supra
180 bit low for oil in my eyes 215 is 100c dead and well for oil 90-100c i always thought was a good operating temp 110+ well getting a bit warm chances are it wont get that warm all the time
reason
different car i know but my mother has a volvo 440 turbo now that runs about 80-90c oil temp on general runs but sit it at120mph for a while oil temp runs 99-101c all the time and thats a standard er well slightly modded car
chance are jake it will only get to the cooler when it is havin a caining and once going round it proabaly wont get any hotter but it is somethin i will monitor when up and running and if i feel a threat i will make changes accordingly
but i do appreciate your concern best pal :icon_bigg
yannis-supras
Lag hater
Jun 13, 2005
331
Athens, Greece
Nice!!! Good stuff man, good to see you're doing some progress again. Couple of questions on your new gear; did you buy your TRD oil filter locally in the U.K. and how much was that?
Also how come you went for the Canton oil thermostat and not for a good ol' britt mocal unit that is like 3 times cheapper? Any particular reason? I now there must be something...:naughty:
