lmao again this a comedy thread i reckon
kind of figured it might be worth putin anothe on with the power i'm gonna have
it is a dead 90 but it is very tight so i'm going to get my mate to do me a 4 section lobster weld special so that there is no leg on the bendIHI-RHC7 said:So how steep of an angle is it from your compressor outlet to the IC plumbing, is it sharper than a 90?
billspreston01 said:i'm sure by the time you get the car running they'll have the stuff you need. Or I'm sure you could fab it up
dont suppose you would be good enough to have a look for me ian cause i'm useless at determinig threadsIJ. said:Steve: Very nice!
and YES you do need those wing brackets (not sure if Ecks was joking or not)
You have 3x 1/8Bspt holes and 1x 10x1.25 parallel holes for oil pressure.
Temp's going to need an adaptor from the water neck size that uses a crush washer to your Npt fitting. (I'm using the stock sender so haven't even looked at the size)
