Hi LD ,Im not sure that i can be much help to you as i think your knowledge on Supra is greater than mine. But I can only pass on my experiences. With regard to my car, it arrived from Japan with 10 degrees of caster, 4000l lb springs, shocks that would do justice to a Mack Truck and on the deck. That may have been fast if we were racing on a billiard table, but here in Aus. the circuits are anything but. The caster played havoc with the power steer and put great strain on the hoses etc .I believe they ran that much to induce camber on turn. It was a fad at the time and never worked. We wound it back to abt 5 degrees and all has been well. The same applied to the springs . the car was that stiff that when I drove the car, it would bounce al over the track if it hit a bump. The stiff shocks were there to control the springs. We chucked them all out and started again and ended up with 1500lb fronts and 1000lb rears and backed the shocks off to suit The same applied to the ride height . They had it so low that it scraped its ass every where (this was another Japanese trend back in the day) and there was no compliance. Here was a car with very sophisticated suspension being run like a go kart. We then raised the ride height to a point where the suspension was doing its job and the tires no longer hit the inner guards . The car is now much more forgiving to drive and doesn"t feel nervous. LD, with regard to the roll centre , we have not played around with it, other than raising the ride heights I hope to look at that area soon. We have tried a number of shocks and have used double adjustable alloy Konis but have settled on Bilsteins. I hope that this is some help to you. Regards Smithy
