Well the egr cooler gasket blew out, so I decided to pull the motor and do some more refreshing up that i shouldve when I originally built the motor.
It got New rod bearings also, They looked really good except had alot of trash in them. I cleaned the engine and parts really well before assembling i dont know where all the trash came from.
So It got new aisin Oil pump, New piston Squirter bolts, AZ performance high flow oil pipe, New woodruff keys, new balancer bolt, Oil filter relocation, full flow oil cooler, BBC Valve springs and valve stem seals, 560 injectors, adjustable fuel pressure regulator, Cummins Turbo oil drain, EGR delete, Manifold and exhaust housing getting ceramic coated, Everything I can get off is getting powder coated.
