Greddy Turbo's
guards_man79
74
Georgetown, KY
how come i don't see very many guys with mk3's using greddy turbo's? does anybody know where you could find a bigger kit for the mk3 than just that
td06sh-20g, cuz what if your a greddy guy wanna go with more than the 450whp?
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
You can go with a SP if you want a kit.
http://www.mvpmotorsports.com/Templates/frmTemplateM7.asp?SubFolderID=340&SearchYN=N
^ at the bottom. Also you should provide more information if you don't wanna get flamed. You wanna make 450rwhp at what boost? what prior mods do you have? how streetable do you want to be? will you run race gas? need more info, ALSO you can always try the SEARCH
guards_man79
74
Georgetown, KY
as far as plans i'm just trying to do something different. i see lots of guys using the sp turbo's and garret turbo's, pretty much just all the same stuff. i'm just trying to do something different. as far as hp i'm not sure how far i wanna take because i'm likely to want more once i reach a certain goal. i'm pretty much just lookin at doin like a j-spec type supra, all jap parts with the exception of a few parts. mainly greddy and blitz, that's why i an wondering about the greddy turbo's and how many guys have used them and how they like them. i'm also wondering about the td07-25g that greddy makes and how much power they can make on a mk3. and how much power a T-78, T-88 and T-88H can make a on a mk3.
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
Depends on the boost you wanna run, those turbos can make up probably 850rwhp if you have a FULL race motor on the t88h but thats race gas, and not to mention will it clear the hood? is it streetable?
guards_man79
74
Georgetown, KY
not sure just yet what kind of boost i wanna push. i'm gonna build it to run real high hp right off the bat, kinda gradually go up and up. i do plan on getting a ron r ffm to shortin the path and make more room for the turbo not to mention the turbo is the show piece of a turbo motor. i'm just trying to do something different.
guards_man79
74
Georgetown, KY
uh yes i am, i don't care what brand i just don't wanna do the same thing as everyone else. but is there any intelligent input from ppl about greddys different turbos
6,653
Canada
I have been using GReddy turbos since day one. From a TD06 with 500RWHP to an RHC7 from Japan making 620 and now I run a T88 which is back on the dyno tomorrow! All in all, GReddy makes a great turbo and is why I keep using them. :) It is all completed but this is the only pic I like to show which is not.
Here is my set-up
Duane
PS: The GReddy turbos are not near costly as some out there.
guards_man79
74
Georgetown, KY
i've always liked your set-up duane, i noticed your car along time ago on
7mpower.com. one of the nicest mk3's out there. the T-88 you're using is it the 33d, 34d, H, SPL, or GK and what kind of power do you think you're going to be able to make from it?
Dec 3, 2003
6,653
Canada
It is the 34D. I hope to make between 760-800 on boost. (which is what most 2J's put out) I don't know of any 7M with this turbo that I can compare. I may put a bigger wheel in it next year to bump the power but will need a clutch that holds my goals first. On spray I hope for allot more power and I will find out soon enough since it is back on dyno tomorrow :D
Thanks for your kind words.
Duane
