I posted this on SF, but im not holding my breath for a decent answer, so I decided to post here.
I have searched and found that many people have asked this question and not gotten a straight answer. All I am looking for is an explanation of which wires coming out of the aristo ecu need to be spliced/ connected into the brown and blue wires on the SLC.
Fill in the blanks
Red= Power. Connect it to a power source (wire color may not matter)
Black= Ground (connect it to a ground wire, usually black)
Brown= ECU Speed Signal(This wire is the color ______)
Blue=Speed signal sensor(This wire is the color______)
Yellow= optional (if you want to raise your speed cut, connect it)
I already have the "manual" from Greddy printed out.
You can not pull the trac fuse on an aristo setup. (there isnt one)
I do not want to cut the pink wire. (it throws a CEL)
Does the pink wire just need to be tee'd into, with the brown wire going closer to the ecu and the blue wire being further away? (sensor side?)
Thanks for any help in advance. I am not good with wiring and I would like to be 100% before i do this.
Fill in the blanks
