nosechunks;1408670 said:The curiosity i have is how it can raise factory rev limiter.
Fuel cut can be worked around, but rev limiter seems more difficult.
Anyone have more technical information on this?
isnms;1409070 said:martin - that second one is mine not drjones, thanks for citing source
http://www.supramania.com/forums/showthread.php?t=86795
Only two signals are severed – KS (AFM) and SPD (speed)
The other signals are only tapped
some more info:
• http://tinyurl.com/qdpjvt
• http://www.mkiiitech.com/forum/showthread.php?t=921
edit: I wanted to add, for anyone looking for a RebicLC. You shouldn't have to worry about doing any wiring. It should come with a harness that has a wedge you just connect your engine harness to and then connect the wedge to the ECU. Plug-n-Play.
like so:
