Thank you guys for the kind words. I'm very happy you're pleased with the work
Your engine bay is looking superb Brandon!
Sawbladz said:
I like the look alot. How long have you had the parts in the engine bay? I have heard from a few people who have had their parts coated that they turned a dull grey over time. I beleive the ones that turned grey used Fireball coatings but I would have to double check. I was just wondering what he used and how long the lustre lasts.
This is a 2000 deg rated, mil-spec coating...it will not turn gray on parts that do not get hot. On exhaust parts, it will turn a titanium gray, but will never flake, bubble or chip. Applying it correctly is expremely important...I bead blast the parts clean, apply the coating (exhaust parts are done on the inside too), bake it on at 500 deg for 2 hours, and polish in a bead polisher. The final polish is done by hand using Blue Magic polish. Once its on, dirt/grease will clean right off using almost any good cleaner...409 works well for me.
Chris - yep, did his turbine housing too
The powdercoatings I've seen dull over time...seems the heat under the hood eventually causes the coating to degrade.
