Put a PL20195 on our 90T today. it's about 1.3" taller than the 10241 that's called for. Same bypass PSI and O.D. it's the ford application filter. I just tapped some metal shroud out of the way 1/4" and it's plenty clear. for some reason theres a metal shroud? over the motor mount???? Either way, the PL20195 fits fine. Figured I'd share the info.
Man is it a pain to get the filter itself in/out of that filter area. How are you supposed to do it? I usually have to push the lower Rad hose up and out of the way and wedge the filter out toward the front.
