i just got one a few weeks ago off of egay. very nice looking radiator. took a bit of modification to make it fit though. i had to bend the lower mounts down because the radiator is a bit tall and it would have hit the hood. the top mounts line up okay, but not perfect... they needed some motivation.
my main problem was the mounting locations for the fan shroud. the holes where the shroud should bolt up were raised so it left a big gap between the shroud and radiator. i used a bunch of weatherstrip to fill the gap. if i wasnt running efans (with a skinny shroud), i would have clearance issues with the belts
