GM 3bar Map Sensor Question
johnd
278
Ont. CA.
I got my 1j running flawlessly with 3bar, it just took time tuning.
how many site's or tuning blocks does the safc give you?
OneJArpus
2,798
ok Here is my dilema, Some people say O 1jz here i got the gm 3 bar to work with my setup on stock ecu but no one is specific on HOW they got it to work
Stock MAP Sensor Readings & Settings on SAFC
What i see when I turn the car on monitor with stock MAP
Sensor Type for Stock MAP
Sensor Check on Stock MAP
Now GM 3 Bar with sensor type 1 / 1
Its already reading it as if it was boosting...
Sensor check - Difference of GM is it reads nearly 5 volts on the "in" line to the safc compared to the 2.xx on the stock map
Change to 2, 3, 4 and all look similar to the pic above
i go to 5 and it looks like this
Still in positive pressure with 5/1 sensor type
I finally get to 7/1 and it looks like this
with the above setup at 7/1 car idles good (small vac leak.. i usually see -480/-500)
I was just wondering if anyone else will shsare there settings with the GM MAP on a SAFC?
Also, i hear some people saying you can raise FC on the stock MAp and that you've done 22 psi on stock map. HOW?????????? I'm htiting cut @ 14.7 on the nose
inline6fan
need some six-ness
Jun 5, 2007
Maine
You guys sounded like this was an option.
All you have to do is wire the MAP ->AFC->ECU?
So you are controlling the MAP voltage with the AFC, then sending the signal to the ECU?
