Little backround, I am currently runing coilovers on stock size wheels and tires. I have 17x9 +35 and 17x10 +20 wheels on the way and they will be mated with 255x40 and 275x40 tires. I will also order the poly bushings kit for front and rear along with new OEM front lower ball joints.
Right to my question, what do I need?
What are the benefits of the Beech or Battle Version rear links (camber,toe and traction) and the Beech front upper control arm?
Are these what I need or can I get away with new OEM front and rear camber bolts,nuts and washers since I'm not sure if the original are seized or not.
Car will not be crazy low due to my wheel/tire sizes choosen.
Thanks for any input in advance.
