Gearing Change Calculations
honestabe
Happy as hell :D
Jan 15, 2006
3,713
Mount Vernon, WA, USA
I'm going to be changing from a 3.73 diff to a 4.10 diff. By my calculations that's just a hare under 10% higher. Is my theory of losing 10% off my topend and gaining 10% on acceleration, and 10% higher RPM's while driving at the same speed in the same gear correct? I don't seriously think I'll be going over 130 M.P.H. very often, even on the track, so I'm not worried about the top end too much.
Adam
8,898
Well, you need to multiply the individual gear times the diff ratio to get your true reduction. That will tell you how far you are off.
honestabe
Happy as hell :D
Jan 15, 2006
3,713
That's what I thought. The only thing changing is the diff. The tranny gears are staying the same. Atleast I'll be able to use 5th gear better at higher speeds (who knows, I may actually be able to get my car into 5th before I hit the limiter at 118, although I doubt it.
Adam
