Gauge pods mounted on steering column
born2drv
1,199
Burbank, CA
I've seen some people with gauges mounted on their steering column, and I'm wondering how they did it? Do you put a big T-clamp on your steering column or something? Is there a kit to buy to mount gauges this way or is it custom fabricated?
Thanks.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
one company makes em for a few cars, and i know tein distributes them here in the US, but ours werent on there.
forcefedsupra
aka, Turd Furguson
Jul 19, 2005
463
Jacksonville, FL
Use the Autometer cups and just screw them into the plastic. You might want to grind a little off the tips of the screws because there isn't much clearance.
Inygknok
Tropical Paradise
Sep 22, 2005
488
Puerto Rico
Anyone got pictures of this? I haven't seen pictures of people doing this yet (guess I'm a bit behind on this).
born2drv
1,199
Burbank, CA
ok thanks for the info guys... i decided to get these pods:
http://egauges.com/vdo_acce.asp?Subgroup=Pedestal_Mounts&Cart=1
i bought 2.... one for the wideband, and another for a future EGT pod. seems a little pricey, but its got the swivel so i can get a good line of sight, plus want to see if i can get them to mount at an angle on the top/sides left and right of the column, like have them pointing at the 10:00 and 2:00 positions.
i'll take pics when it's all done, thanks :)
xarewhyayen
276 whp - 324 tq @ 13psi
Oct 3, 2005
959
Philly
Hm i didnt even see this thread, but i just finished the fabrication of mine today... i just felt like learning some fg stuff so i went out n got some resin n cloth. for my 1st mission i did this haha. I got the first thing i could find that was of similar size to my 2inch gauge. i got the cap off my cat's treat bottle. I formed a 5 inch long tube and let that dry, then cut it to get the piece out.
Then i put another piece around it to close it back up, and used the resin to stick it to the column piece ( i took it out of course). Then i put a band of fg on top of it and sloped it over and resin'd it. Then i covered in the spots i missed when i draped it. It looks kinda crude, and def not perfect, but im feeling good for my first try at it. Next time i think ill use chicken wire as my mold. Anyway you can find a few pictures of what i did @ www.tmobilepictures.com/Xarewhyayen
I'm going to sand and paint it up tomorrow
SupraDreamPDR
Boost-a-holic!!
Feb 3, 2006
1,140
Springfield, OH.
not bad man.
xarewhyayen
Oct 3, 2005
959
Philly
SupraDreamPDR said:
not bad man.
Thanks man.. i also gave myself a pat on the back... hopefully i get better though haha
P.S. Use a dustmask when cutting or sanding.. that stuff is dangerous... and the resin is really really potent... i did it outside. and still had to take breaks for air.
Loki
The Future is Unwritten
Prince George, B.C.
Here are a couple pics of my Auto Meter cup.
Loki
Prince George, B.C.
Fastway135 said:
Did you use a screw or a bolt/nut? Because i dont see where the screw would hold on to.
I used 2 screws, they go down through the bottom mount and straight through the plastic steering column cover. You can see them in the bottom pic.
hot dayam mk3
149
i'll post a pic of mine when i get a chance i have a fiberglass pod thats holds a 52mm gauge and my hks turbo timer.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
i had 2 cups on my self last year but now i move em to diffent spot my fule guage and no2 is going to be there now thou
