Gauge cluster issues
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
Tewd matches what my 88 parts car wiring is.... This 90 is a bit different though... My searches haven't found anything that suggests they should be different
Any ideas? :-\
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Well, you already know C-8 is correct so you're doing something wrong. Nothing I have shows A-10 being used.
Verify on the cluster which is the switched 12 volt. Either eyeball it or ring it out using the meter. Since it feeds most of the gages it'll be obvious. Iirc it's even marked on the board as "IGN" but don't hold me to that. Once you ID it trace back to whatever connector and pin it goes to (should be C-8) and take it from there. Once the other side (coming from the fuse) is verified wire it to C-8. I think you made a mistake though.
Again, any time something doesn't make sense or a signal is missing immediately stop and do whatever it takes to verify you're probing the right place.
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
Ok for ease of explanation...
Here is the cluster connections on my 88 parts car the wire colors match the tewd
Connector A
Connector B
Connector C
And here is the connections for my 90
Connector A
Connector B
And C
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
The yellow wire in A 10 receives 12volts with key on and loses voltage when the gauge fuze is removed
I visually traced the back of the cluster and c8 is labeled ign+
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Great. Then move power from A 10 to C 8. You don't care if it matches the schematic, all you care about is it works. Chalk it up to the price paid for swapping clusters. If you still can't get it to work take it outside and do a mag dump on it with that new Glock...
