I'm honestly trying to think of anything that i dont already have, hand tools wise, so maybe you guys can help out here. Now i dont have an engine hoist, or an engine stand (have you seen the PRICE of them?!), but i do have a block & tackle ready to mount up on a beam.
So far i have:
Small Stuff:
90pc Halford Professional Socket Set (1/4", 3/8" & 1/2" Drives & Extensions + TORX/Allen sockets & screwdriver bits)
3/8" Halfords Professional Torque Wrench (6 - 45lb/ft)
1/2" Halfords Professional Torque Wrench (30 - 150lb/ft)
Ball Joint Splitter
Irwin Bolt Grippers (f*cking FANTASTIC!!!)
Feeler Gauges
Steel Rulers (15cm and 30cm)
Digital Vernier Calipers
Valve Spring Compressor
Piston Ring Compressor
Gunson Timing Light
Gunson Brake Bleeder
Gunson Compression Test Gauge w/14mm plug adaptor
Valve Grinding Paste & Stick (dont you love the fact its just a bit of wood with a sucker on the end?
Tap & Die Set
Magnetic Tray
Hammer
Screwdrivers
Angled Needlenose Pliers
Wire Cutters
Soldering Iron & Stand
2 x Multimeters
Halfords FakeDremel (Its a dremel with a halfords badge on it)
Wire Brushes (Drill Attachments)
Simple Electric Drill
No Shortage of Glass Jars
Toyota TCCS Tester
Toyota Cruise Control System Tester
BIG ORANGE FUNNEL!
Big Stuff:
2 x Car Creepers
2 Tonne Trolley Jack
2 x Axle Stands
2 x Ramps
2 x Chocks
What else am i missing guys?
So far i have:
Small Stuff:
Ball Joint Splitter
Feeler Gauges
Gunson Timing Light
Tap & Die Set
Magnetic Tray
Hammer
Screwdrivers
Wire Cutters
2 x Multimeters
Toyota TCCS Tester
BIG ORANGE FUNNEL!
Big Stuff:
2 x Car Creepers
2 x Axle Stands
2 x Ramps
2 x Chocks
