Just got a rebuild put in my 89 Turbo. Just a few minor things needed to crank it. The main thing that I can't seem to find anywhere is a relay. It is not labeled on the top of the fuse cover box, but it's the one on the far left of the fuse box under the hood. There are some wires that need to be ran into it but I don't know where to find this fuse or its purpose.
So I snapped some pictures of the missing relay yesterday. From the people that I’ve talked to thus far, most claim that there was never a relay in that location to begin with. I even went to Toyota to get it figured out, and all they could do was pull up the location of the fuse box itself. I’m fairly positive that there was a relay there before, I just seemed to have misplaced or lost it during the rebuild. If I remember correctly, it was a big relay that had tabs coming out of the bottom of it, where the wires were bolted in. I’m also fairly certain that these relays were only used on the turbo models.
Attached are a few pics of what I’m referring to. It is the blank space on the far left side of the fuse box. Also, I tried to take a picture of the wires that I assume run to the relay (there are some that we twisted together during troubleshooting).
It's the wires twisted together and the other two with the eyelit connector on the end that we can't figure out where they're supposed to go. When we run a test wire from the three spliced together wires to the positive side of the battery, there is power.
All the fuses already have wires ran to them and that far left open slot is what I'm talking about. the abs fuse is missing in the picture but that's in now so that's not it.
Any information on the purpose or name of this relay, the correct wiring, or where to find one would be greatly appreciated.
