Full Throttle MAF Translators
blk92suprat
J Zizzle
Jul 6, 2008
456
USA
Im just exploring my options before I go the lex/550 way.
Has anyone used this type of translator before?
I dont know much about it.
Is this similar to the maft pro at all?
I know it removes the afm completly and converts to speed density but I also heard that it has fuel tuning capabilities eliminatiing the need for an electronic fuel tuning device such as the Apexi NEO.
Searching yeilded this....Any additional info would be great as this thread didnt answer everything.
http://www.supramania.com/forums/sh...ighlight=Full+Throttle+MAF+Translators&page=3
Any input is greatly appreciated.
Thanks
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Err... yes, lots of folks here have used them, myself included. It's the precursor to the MAFT Pro, so it's similar, but without the huge feature list of the Pro unit.
Yes, you can tune your fuel with it, and it will replace a lexus AFM.
shaeff
Kurt is FTMFW x2!!!!
11
Around
The regular MAFT doesn't switch you over to speed/density. It uses a GM hot wire sensor. The MaftPro w/ speed/density harness switches you to speed/density.
blk92suprat
J Zizzle
Jul 6, 2008
456
USA
Is this device plug in play or is splicing required?
Also, how do you make fuel adjustments with this? Is a labtop required?
blk92suprat
J Zizzle
Jul 6, 2008
456
USA
One last question.
By deleting the afm, are all of the vacuum hoses still necesary that plug into the acordian pipe? PCV? ISC?
shaeff
11
Around
blk92suprat;1201216 said:
One last question.
Yes, they're all still necessary.
blk92suprat
J Zizzle
Jul 6, 2008
456
USA
Thanks Sheff.
I guess I need to fab a custom turbo inlet pipe.
Wish there were 4" ones avilable with all the hose provisions.
