Fuel system for 700whp
SupraClaou
846
4
Athens,Greece
I got new parts for my fuel system:
# Sard top feed fuel rail
# Sard 800cc high impedance injectors
(got a jdm 2jz with no resistor pack)
# twin GS341 255lt/h HP Walbro pumps
Fuel lines :
# Custom fuel tank hanger with one -AN8 feed line till the firewall....
# Then goes an -8AN inline 'Earls' high performance fuel filter...
# After the fuel filter goes a ' Y ' splitter (-8AN inlet ----> Two -6AN outlets) for
the two -AN6 feed lines for the fuel rail.
# From the fuel rail goes a -6AN line to the Aeromotive FPR
# And last,from a -6AN port on the AFPR goes the stock (low pressure) return
line back to the fuel tank.
My question is: Will this system support 600 whp on pump gas...and
700+ whp on race (C16) gas?
Things I could change over my fuel setup if I have to:
Two 260 lt/h Sard (intank pumps) instead of two walbros...
-10AN feed line from the tank to the Y splitter instead of -8AN feed line
Please do post your thoughts...:sarcasm:
Supraholics
.928 RWHP & Climing!
Apr 1, 2006
1,577
PA
www.supraholics.com
Keeping in mind that you are installing everything the right way and using the proper components, looks like you have a system that is good for 1000+HP with only your injectors as a limiting factor. Your fuel system should handle your HP goals.
My setup is very similar, but I'm shooting for about 100HP less than you.
blackkarma
MoN-sTaR
Jan 17, 2007
335
jacksonville, nc
looks good 2 me ive a similar setup but im running 880 injectors. i am looking at 1000cc or 1200cc, though ive been told that i shouldnt have to much problem making it with my 880's.
pbasil1
Fully built 1JZ project
Jan 30, 2008
402
Huntsville,AL
Looks great. If you change anything it should be the FPR and -6an lines to a full 8AN through out. But again, for 600-700 whp, thats a beefy system.
Turbo Drifter;1357324 said:
Its about the same size as a -6 line.
Its actually a -5AN (7/16") hard line.
SupraClaou
846
4
Athens,Greece
You mean one -8AN feed line..to the fuel rail,and split it into 2 feed lines?
Or two -8AN feed lines to the rail?
Or you are talking about the return line...?
How big is the oem return line? -5AN?
soapra
860
VVTi'n, CA
www.kaizenmotorsport.com
IJ.;1357766 said:
For 500rwhp as a bare minimum I run
2 x Aeromotive Tsunami pumps
Aeromotive AFPR
2 x Bosch MS filters
2 x -6 fuel lines
1 x -6 return.
+1 :icon_bigg
Or change pumps to two bosch pumps. In tank pumps suck.
Here is a pic of the popular fuel pumps that are used in Supras today.
LOL funny you suggest an ext pump then post a pic of an 040 in tank Bosch :D
I couldn't live with the Coffee Grinder Bosch pumps I was running as my car is so quiet they seemed MUCH louder than I wanted, swapped in the AeroMotives and while better they were still noisy so I ended up PWMing pump #1 as slow as it would go and still maintain the idle pressure I needed then had pump #2 kick in on boost.
My "point" is think of what you need in a fuel system and pretty well double it as there's NO ROOM for error once you start pushing a turbo engine hard it will melt in milliseconds if leaned out on the top end.
Doward
4,245
Alachua, FL
Ian, that's the Bosch 044 pump - lots of guys mount it external ;)
Here's the system I'm a big fan of up to 600-700hp:
MKIV Denso pump in the tank running to a surge tank, with an external 044 supplying the real pressure to the fuel rail ;)
