jetjock;1943216 said:
Not sure why that was hard to understand, but I will try again since I just woke up from a nap. I was very tired, and that may have not made sense lol.
Pull the cover in the hatch to access the fuel pump wiring, unplug the plug that goes to the fuel pump. Plug in one lead of the multimeter (or test light) into the positive side, plug in the other to the negative side. Set your multimeter to voltage, and watch it as you cycle the key, or crank the engine over. It will trigger the relay to come on if it is working right, and should show voltage if it is indeed working right (9-12v I believe if you still have the resistor).
This is just to diagnose if the relay/wiring to the pump is working right, and should isolate the problem as being the pump if you do not have voltage back at the plug for the pump.
