a little while back, i bought a lipp fuel rail through hpf with single 8an feed. i installed an a1000 pump and ran 8an feed and 6an return lines down the car. first off, it was a pain in the ass to put the injectors into the rail even though i lubed them with grease. i ended up returning that rail and the 2nd one wasn't much better. i was even trying to use stock injectors- it made no difference. so i said screw it and dremeled the ports which is when i discovered pits in some of the ports (poor quality aluminum). i tried it anyway, and after fixing a couple of leaks (those pits were shredding the o-rings), it was working. but i don't trust it. any suggestions? i would like to have one of the power house racing rails but i guess they don't make them anymore. i really don't wanna re-fanagle the feed line either. anyone had experience boring stock rail?
